3d printed movie accurate arc reactor with modular cores allowing for movie accurate lights and the ability to charge a phone wirelessly.
wireless circuit cover.stlStandard Tesselated Geometry - 1.64 kB - 08/25/2019 at 01:54 |
wireless circuit holder base.stlStandard Tesselated Geometry - 6.63 kB - 08/25/2019 at 01:53 |
outter diffuser for wireless charger.stlStandard Tesselated Geometry - 172.05 kB - 08/25/2019 at 01:36 |
center triangle diffuser for wireless charger.stlcenter piece required to make light diffuser for wireless chargerStandard Tesselated Geometry - 43.25 kB - 08/25/2019 at 01:34 |
So to make the body as I have you can purchase it on various sites like ETSY and such listed in the YouTube vid and Instructable if you want to save the time CADing it up yourself using the reference photos and vid of the real prop linked in the Instructable. The parts needed for the wireless charger core are included for free here in the downloadable files section. Instead of using the electronics panel included in the payed (only like $10 bucks to cover months of development) version you need the two included diffuser pieces and the pieces to hold the wireless charger circuitry. You will need to purchase the wireless charger I have linked or one similar to it in size. The size of the one I got was very compact. It
It's really easy to just forcefully open it up and use all the wireless charging entrails to your hearts content.
To build the basic body I have an Instructable . I'll be updating how to do the whole wireless charger part here and as a separate Instructable and YouTube video.
https://www.instructables.com/id/3d-Printed-Endgame-Arc-Reactor-Movie-Accurate-and-/
You'll need 3mm leds that are cool white which will need to be sanded down to 1.85 mm in thickness to superglue into the diffuser slots. I currently have them wired to a resistor and 9v battery but plan to change that to one of the plugs on the lipo charger pack I have to hook the wireless changer to. That will make it so I don't have to wear a shirt with a hole in it to get this thing all powered.
I'll keep adding instructions here as I go.
solid idea. There are wireless chargers with a longer charge distance too. but I'm not sure they will fit. Maybe for my Thor hammer project.
A version with MagSafe would be cool so my phone could magnetically stick onto my chest to charge. Lol.
