Here it is August 25, 2019 and I still don't have live P2 hardware to port my code base over to. Still I venture on, and will continue to work with Windows 10/Visual Studio and the P1 hardware, as well as conducting experiments with the P1 stuff that I have so that when I do get the final hardware - it will be possible to simply configure the filtering and processing algorithms by, for example, simply describing the filter tree in XML or maybe in SCRATCH! (even if that is a bit far out there!)
glgorman
