There's now a screenshot command which generates an XBM bitmap over the serial port. Here's a few screenshots for your viewing pleasure. Note the ticks on the profile display, each tick represents 20 degrees (or 5 degrees per pixel) across the Y axis. As for seconds, each tick represents 20 seconds (or 5 seconds per pixel) across the X axis.
Main Screen:
Config:
Profile Edit:
Test Out:
Reflow:
