This was pretty simple and easy. Just used requests and a simple class to provide API access.
You'll notice, however, it's not just a list of orders. There's also this meta part, which has some miscellaneous that I didn't find docs on or uses for.
In each order though, there is a ton of data. Even data for features Tindie doesn't support yet - like preordering. Interesting!!! I certainly hope they support that soon.
Anyway, if you are interested in more I highly suggest playing with the API. There doesn't seem to be much docs on this, but it certainly works.
Dylan Brophy
