I changed the code so that it takes 3 images and averages them, instead of taking 1 image. This dramatically improves the precision of the device.
I found a major bug in the code: the x-axis was reversed! This escaped detection because there are peaks on both edges of the olive oil spectrum. But when I started averaging images (see above), it became apparent that the right-side peak was much bigger than the left-side peak. This is incorrect; it caused me to investigate and find the bug. I still haven't fixed the bug; I need to do this before taking more measurements. The spectrophotometer is currently NOT accurate (because of the bug); it should NOT be used right now. I hope to fix the issue soon.
