The idea behind this project is to create a product that can be made entirely at the DesignLab, using the equipment available at hand. It should be relatively easy to put together, not (that much) labor intensive, and interdisciplinary.
For this project I have the help of my amazing team members: Voja Antonic, Bruce Dominguez and Erika Earl.
Giovanni
The precision on these machines is very good. The cycle to pick a component and place it on the board has quite a few steps that I am unable to describe, but Erika would in a heartbeat. Essentially, the machine takes photos of the nozzle (?), board fiducials, grabs component, goes for another selfie and then flies over to the exact location where such component should be placed.
We could say the process was started with the question: What simple, reasonably consistent and repeatable and processes is available at the Lab? Laser cutting of course. There are CNC mills and 3d printers but with laser cutting, once you have a predetermined shape, it basically becomes a "push a button" task. The next step, acrylic bending is not too complicated and I am planning to make a bending jig out of MDF soon.
Victor Dedios
Ian Shannon Weber
SUF
sjm4306
