The biggest challenge right now is I/O into the system. I'd eventually like to support
- Keyboard
- LCD
- Serial / UART for attaching modems and other such things
- Compact flash drive
- A Counter/Timer Circuit (CTC)
Last night, I realised I could use a handful of PIO chips to do the bulk of the work. The LCD, which is 8 data pins and 4 control pins, could be controlled by a single PIO; the keyboard probably needs to be connected to a small microcontroller to handle strobing the entire keyboard (which is necessary to pick up modifier keys). Serial I/O is done with a separate chip, the SIO/2 that provides a pair of ports. I think the compact flash could be done with a pair of PIO chips, maybe connected to a microcontroller but maybe not. My compact flash is an IDE <-> dual CF interface with an ATA-44 connector, so that'll need some thinking. The CTC would be used for threading as well as a general counter and timer. Tentatively, I'm designing around the following addressing scheme:
DEVICE ID CONTROL
D0 D1 D2 D3 A B C D
A7 A6 A5 A4 A3 A2 A1 A0
1 0 0 0 | SIO/2 (BASE $80)
0 1 0 0 | DIRECT INTERFACE (KBD+LCD) (BASE $40)
0 0 1 0 | CTC (BASE $20)
0 0 0 1 | ATA (BASE $10)
SIO/2
A: ENABLE ON 0
B: 0
C: C/D (CONTROL=0, DATA=1)
D: A/B (PORT A=0, B=1)
SIO A/C: $80
SIO A/D: $81
SIO B/C: $82
SIO B/D: $83
DIRECT INTERFACE
A: ENABLE ON 0
B: KBD/LCD SELECT (KBD=0, LCD=1)
KBD A/C: $40
KBD A/D: $41
KBD B/C: ---
KBD B/D: ---
LCD A/C: $44
LCD A/D: $45
LCD B/C: $46
LCD B/D: $47
CTC
A: 0
B: ENABLE
C: CS0
D: CS1
CTC0: $20
CTC1: $21
CTC2: $22
CTC3: $23
I still need to figure out the addressing and interfacing for the IDE/CF drives (as well as figure out what the file system is going to be).
I think the interrupt priority is going to be:
- keyboard (always give the user priority control)
- CTC
- SIO/2
- IDE
- LCD (I don't actually anticipate any LCD interrupts, but I'm building this in case it becomes useful later)
