The terminal blocks are in, so I finished assembling the mainboard and power board. I realized that I'd put the wrong part in the first power board (LD333V instead of an L7805), so I had to assemble a second power board (I guess this is why they send you three ;)). It passes the output checks (4.96 and 3.35V), and look at that clock signal!
Kyle Isom
