This is a follow-up from the earlier "Propeller Weekender" project: https://hackaday.io/project/167189-propeller-weekender-sd-card-experimentation
With the SD-Card working, it's time to test it with this little MIDI file player! Will it work? Should it need some more improvements? :)
Note: MIDI format 0 only supported!
YH-workshop
bobricius
Shahriar Alam
Pete Prodoehl
re4mat
