Miniature Plastic USB Enclosures (1551USB Series)
- DWG files from manufacturer can be converted to DXF with https://cloudconvert.com/dwg-to-dxf.
- After cleanup with LibreCAD and a check for the correct scale, the file can be imported in EasyEDA.
