1Step 1
To begin, follow this link to access SelfCAD software and launch it. https://www.selfcad.com.
Then:
- Select a Standard Primitive - Cylinder
- Set the following parameters:
- Top and Bottom Cylinder radius 40
- Height 10
- Horizontal Segment 2
- Vertical segment 24
- Arc 360
2Step 2
- Rotate it by 90 degrees
3Step 3
- Make 2 copies with Copy Offsets Tool:
- For first model set value 200 on axis X
- For second model set -100 on axis X
4Step 4
- Scale the middle copy and set values:
- X: 195
- Y: 70
- Z: 70
- Select and isolate middle object from other objects
5Step 5
- Make two copies with Copy Offset Tool
- Scale copied objects with values:
- X: 210
- Y: 65
- Z: 65
- Hide copied element
6Step 6
- Select main and copied object and use Stitch and Scoop
- Than use Difference option and select copied object
- After that isolate differenced object
7Step 7
- Select visible cylinder.
- Choose Cube Selection tool and make selection with values:
- Left 5
- And Right 198
8Step 8
- Use face selection mode and choose top faces with help Right Button Mouse and then delete them
9Step 9
Use Add Thickness tool with value -2,5
10Step 10
- Choose copy and use Move tool to transfer it on 150 on axis X
- Then make it a little bit smaller using scale with values:
- X: 209
- Y: 64
- Z: 64
