Watercolor on paper. One brush. Eight feature layers - 2 water paint, 2 watercolor paint, 4 watercolor blend. 30 minute paint time. Each feature layer used a different combination of the brush symmetry, brush angle offset, and max paint distance parameters. The tool paths for this painting were drawn manually in a vector image manipulation program. This painting is a prime example of the brush techniques possible when using a fourth axis tool chuck.
John Opsahl
