MORE INFORMATION
SICONICA.COM
WaterJet for drone
Да, контактируют, но установлены моторы с заводской водозащитой.
What's the targeted depth? I am very interested in 150m operation depth with at least 30m margin (max 180m) or 100m operation depth with at least 20m margin (max 120m).
I tested it's motor only at a depth of 50 meters.
that if you connect several motors to a 12-watt battery, print the case on the printer. Make it the equivalent of a water scooter
Yes it is possible. I can design models with more thrust.
Moves a lot of water for such a small engine. I'm impressed!
Certainly looks very cool. Are there any numbers on thrust? Is the performance actually improved by the "jet" design versus just putting a prop on the bare motor?
Thanks :) Thrust - 1.3 kg. It's design allows to better control under difficult conditions - wind, waves, flow on the river.
The website is down, and the 3DP files don't seem to be available. I think this would make a fantastic bow thruster for smaller boats, or an excellent option for electric kayak. Are the files still available?
