A colorful log this time.
The CPU is completely routed now. I used a mix of automatic and manual routing.
I chose a DIN41612 connector for the CPU (3 rows of 32 contacts). The middle row of contacts is not used.
The PCB size is 4.0 x 5.575 Inch ( 10.24 x 14.15 cm ). Clicking on the pictures gives a slightly larger image.
You will see component placement, top layer, bottom layer and their combination here. Clicking on the pictures gives a slightly larger image.
