Version 0, revision 1
Parameters to test:
- Linearity of 10V voltage measurement range
- Linearity of 500mA current measurement range
- Linearity of 5mA current measurement range
Features to implement:
- Use built-in low power comparator to switch current range
- Use built-in low power comparator to detect over current
- DC offset storation and calibration
Hardware modification to test for new version:
- Easy selectable boot mode with jumper
- Drive LED directly with GPIO, without transistor
