This is a simple Datalogger with two controllers
The latest test came to a runtime of about 2,5 days.
On the SD Card i Found ~20.000 Measurements.
I only expected something like 7200 Measurements.
Somehow the cycletime of the MSP430 increased by 100%...
Here is the Datasnipped:
DateTime ADC Value Voltage Temperature Humidity Dist1 Dist2 Dist3 delta time 12.09.2019 20:35:20 215 6,24 28 45 223 799 200 12.09.2019 20:36:46 216 6,27 28 44 116 118 116 26 12.09.2019 20:38:12 216 6,27 28 44 117 118 118 26 12.09.2019 20:39:38 216 6,27 28 44 117 119 117 26 12.09.2019 20:41:04 216 6,27 28 44 118 116 118 26 12.09.2019 20:42:29 216 6,27 27 45 118 117 117 25 12.09.2019 20:43:55 216 6,27 27 45 118 118 116 26 12.09.2019 20:45:21 216 6,27 26 47 118 116 118 26 12.09.2019 20:46:47 216 6,27 26 47 118 118 118 26 12.09.2019 20:48:13 216 6,27 26 47 118 116 122 26 12.09.2019 20:49:39 216 6,27 25 47 118 118 122 26 12.09.2019 20:51:05 216 6,27 25 48 121 116 122 26 12.09.2019 20:52:31 216 6,27 25 48 122 120 118 26 12.09.2019 20:53:57 215 6,24 26 63 118 119 118 26 12.09.2019 20:55:23 215 6,24 26 60 118 117 118 26 12.09.2019 20:56:49 215 6,24 26 59 118 118 117 26 12.09.2019 20:58:15 215 6,24 26 58 118 119 118 26 12.09.2019 20:59:41 216 6,27 27 60 65 64 114 26 12.09.2019 20:59:52 217 6,3 27 60 49 49 55 11 12.09.2019 21:00:02 216 6,27 27 59 190 138 128 10 12.09.2019 21:00:13 217 6,3 27 58 130 199 143 11 12.09.2019 21:00:23 217 6,3 28 56 119 118 119 10 12.09.2019 21:00:34 217 6,3 28 55 118 118 119 11 12.09.2019 21:00:44 217 6,3 28 54 118 119 118 10 12.09.2019 21:00:55 217 6,3 28 54 119 118 118 11 12.09.2019 21:01:05 217 6,3 28 53 119 118 118 10 12.09.2019 21:01:16 217 6,3 28 52 118 118 118 11 12.09.2019 21:01:26 217 6,3 28 51 118 119 118 10 12.09.2019 21:01:36 217 6,3 28 50 118 118 118 10 12.09.2019 21:01:47 217 6,3 28 49 118 118 118 11 12.09.2019 21:01:57 217 6,3 28 48 118 118 118 10 12.09.2019 21:02:08 217 6,3 28 48 118 118 118 11 12.09.2019 21:02:18 217 6,3 28 47 118 118 118 10 12.09.2019 21:02:29 217 6,3 28 47 118 118 118 11 12.09.2019 21:02:39 217 6,3 28 47 118 118 118 10 12.09.2019 21:02:50 217 6,3 28 47 118 117 118 11
So i found two Problems:
- The intervalltime was to short
- The ADC was not working properly.. (It should have recorded the Voltage of the batteries, but the value stays almost the same the whole time)
Hints, Thoughts and Comments are recommended.
Testing went really bad until now..
