Adding LEDs to things that don’t need it is something I like to see. I got this art piece at AT Home. I cut up a bunch of RGBW LED strips to allow the trees to glow. This is mounted above a dining bar that I also installed LEDs on.
The LED strips where cut and taped onto the art prior to soldering the wires:
Soldering the wires and testing with the controller:
The Art on the wall powered on:
Art still in the "box":
