Here is the plan. I plan to turn this
into this
And here is the design block diagram.
There will be 3 sensor node and a nutrient control system. All of them is developed with ESP8266 board (either WeMos D1 mini or NodeMCU). I plan to use Blynk IoT Platform for easy and solid mobile app UI. Futhermore, with "Metabase" as website data visualization platform.
The system can be divided into 3 parts:
1. Sensor Network and data acquisition.
2. Nutrient Control System with Blynk Bridge to fetch data from pH and EC sensor.
3. Metabase Website Data Visualtization.
