Actuator Repeatability Test
A project log for (8:1) 3D Printed Planetary Gear Actuator Module
3d printed 8:1 planetary gear ratio actuator module with VESC firmware based circular motor driver
dongil-choiDongil Choi • 10/11/2019 at 23:01•0 Comments
Repeatability Test
The fully 3d printed 8:1 planetary geared actuator is controlled by mj-vesc(https://hackaday.io/project/167706-mj...). The precise position servo control is done by goto control mode(https://hackaday.io/project/167706-mj...). In this video, it shows the repeatability of single actuator. The result shows that it guarantees sub 0.01mm accuracy (standard deviation : 0.0058mm measured at 150mm from actuator center)
