Preparing for a proper enclosure
A project log for My Very Own Geiger Counter
Fulfilling a childhood dream
jon-kunkeeJon Kunkee 11/09/2020 at 07:370 Comments
With the electronics successfully mounted to the foam board and a good chunk of the programming done, Version 1 is done.
It is now time to face my nemesis, the enclosure, for Version 2.
Some time ago, once I had the larger components figured out, I acquired a Hammond Manufacturing 1591XXESBK project box for this. (This is what provided the outline and size constraints in the v1 mounting post's pictures.) I also found a shiny power button, some nice tactile buttons, and a couple of switches to go with it. A few protoboards, some solid wire, the upcoming long absence of a friend with hand tools know-how, and the motivation of participating in the Hackaday Remoticon got me over the line to start prepping the project to get bolted into a proper home.
I ruminated a bit about how to fasten circuit boards and screens to the front plate and ended up at "If I can roughly lay out the front-plate elements, I can group them by component height and build up the boards. Once they're securely on boards, my friend can help me figure out mounting."
This started with a sketch in OneNote, where I added notes and boxes as I picked where to put what:
case layout and wiring diagram
This sketch lays out where the major components will sit in the bottom of the case, where the major connections are, where the user-facing elements will sit, what kinds of boards they'll be on, and some other design choices like LED current-limiting resistor selections. I ran out of time, so the LED board connections are not yet charted out.
Button Board
The first board was pretty straightforward: a 100-mil header and three buttons:
front of button board
Here we see the three tactile switches with their keycaps and some soldering connections visible.
back of button board
Note how I ran the ground connections all along one edge and the digital I/O connections along the other, all terminating at a side-facing 100-mil header.. This board was simple enough that everything is relatively pretty.
The only real challenges here were working with the header-end of the wires to make sure nothing shorted. I double-checked the button pin assignments several times, then did a round-robin continuity check after I was done to make sure everything was working.
Switch Board
The second board was more challenging. I misread the mechanical drawings of the toggle and on/off/on switches I bought, so the pin spacing was wrong. On top of that, the 250Vx2A-rated leads were too thick to fit through the holes on my board. By happy happenstance I noticed that some wire terminals I had incidentally acquired (in a bundle with the perf board) were 100-mil spaced and the switch pins fit into the screw-down terminals. I'm not sure how I'll attach the resulting combination to the front plate, but it works and provides a nice place to mount the IR receiver:
switch board component side
Here we see the switches in their screw-terminal receivers along with their respective 100-mil headers (that are, yes, askew). The IR receiver is in between the switches facing towards the surface the switches will project from. I ended up soldering the IR bit last, and it was a bit of a pain having to dance around the two big blocks of plastic next to it. Fun fact: the IR bit was placed here after I thought I had finished the board and realized it didn't really fit anywhere on the LED board (described later).
switch board wiring side
I had colorful wire, so I partied on this board with its small but relatively simple wiring. I really need to figure out a better way that isn't PCB design--a challenge that will have to wait for another day.
switch board screw terminal abomination
In case you missed it, yes, that is a three-port screw terminal block with a switch shoved in it. I'm sorry, but I can't be held responsible for any ocular distention or gouging as a result of this slightly comically bad hack. Hey, this is "Hack"aday.io, right?
Oh, and in case you're wondering about the excessive free fiber content in these pictures, they were project contributions of a feline variety.
LED et al. Board
Once that was done, it was time to do the hardest part: the LED-and-everything-else board. I settled on implementing the GKPlus kit's tone (click and squeal base pitch) control circuit, so I needed a potentiometer, I had the aforementioned shiny power button to suss out, and the various status LEDs from various subsystems needed to be surfaced.
(I would like to plug Adafruit's "Order Through Digikey" feature and Digikey's customer service. The power button was not in stock on Digikey, but their customer service team worked with me to get it added to a batch of bits coming from Adafruit. I then bundled it with a few other components like the switches and not pay $12USD shipping for a single switch.)
After mostly settling on what would go on the board, I realized I hadn't thought through what LEDs I would use beyond the one in the power button--so I scrounged through my stuff to find some. I found a few, but I had to to characterize them since their provenance was long lost. I found a few surprises!
One round, red LED was extremely normal, with the classic 2.2V forward voltage and full brightness at around 10-20mA.
The second red LED was a little weird. The forward voltage was low but normal at 1.9V, but the brightness seemed normal at about 1.5mA. I'll need to check to make sure this is right; I seem to recall it being kind of dim after I got it soldered down.
The green LED? That was just weird. The 2.1V forward voltage was pretty normal, but the 0.25mA full-intensity LED left me double-checking my multimeter, resistors, and wires. These last two came from a little baggie with a CR2032 battery and some reference cards from Adafruit, so it's entirely possible they really are this weird and were intended as part of an LED throwie or something.
With resistor values picked and all the GKPlus-related components roughly laid out, I started soldering everything down:
LED and misc board front
This half of the board has the speaker, tone potentiometer, detection LED, and status LED. Note the bare ground buss bar (stripped solid wire) on the left and the rat's nest of jumper wires connecting everything to the correct pins of the 100-mil header poorly situated in the middle of everything. (It probably should have run parallel to the buss bar between the LEDs and the speaker/pot section.)
LED and misc board, bottom
I honestly don't expect these photos to capture everything that's happening here. The LED current-limiting sensors connect the LEDs to ground, while the tone pot base value and filter capacitor just kind of connect everything to everything. This board is mostly dead-bug construction, leveraging the component leads as wires. I sure hope it works; at least the LEDs do.
Out of Time
All of this got done on the Saturday of Remoticon, so I was more than a little tired at this point. Around 12:30AM local time, I finished up the GKPlus side of the board, tested it (noticing the second red LED was dimmer than I expected), and packed it in. The power switch/power LED/charging LED half will have to wait for another day--preferably before Saturday when I'm risking properly-masked-and-social-distanced contact with my friend in his garage to drill holes and cut windows for mounting everything.
The firmware will get finished after that; it turns out I'm down to looking for 100-byte scale savings and I still have more features to implement. Eventually. :)
Rich text editor
