I now need to define the main control loop; and implement it.
- One reading every 30S and then decide how to set fan.
- Power Control
- Vmin->11.8V : Powersave mode; no activity, wake every 30s to take and process a voltage reading. Ignore button
- 11.8->12.6V : Low Power Mode(s); start running the fan; limit max speed. respect quiet/off overrides
- 12.6->Vmax : Full power mode. respect quiet/off overrides
- Fan Control
- Need to think about this
- User Control
- Off/Quiet/Idle
- Average readings; discard outliers
- Testing will be tricky.. I'll need to 'fake it' somehow for the humidity/temp readings.
- I'd like to use interrupts and have the controller sleep between readings/decisions.
Owen
