Ocean Test No. 2
07/17/2014 at 21:14 • 0 comments7/17/14 - We completed the second test of the SolarSurfer in the ocean. Last time, we only had an RC receiver and we drove it around manually. This time, it had a full blown autopilot with GPS, compass, and an IMU.
We stored at set of waypoints in the autopilot's memory. When switched into autonomous mode (via the RC transmitter) it automatically navigated between the waypoints. Amazingly, it was totally successful on the first try. Check out the map image that shows the waypoint path and the two test runs. There's an interactive version at
www.bluerobotics.com/images/map/SolarSurfer-Test2-GPS.html
Ocean Test No. 1
07/04/2014 at 15:53 • 0 comments6/28/14 - We completed the first test of the SolarSurfer in the ocean. Using RC control, we tested the speed and steering. A GPS track was recorded to verify the speed.
