10/28/2020 at 06:10 • 0 commentsOne of the new finds with FoxyPI MD (before and after electrolytic cleaning):
Metal with magnetic properties, the shape is close to a hexagon with a side length of about 8 mm, the edges are uneven, and there is an asymmetrical hole in the middle.
Old handmade "iron" button?
Signal curves
10/19/2020 at 05:55 • 0 commentsExamples of signal curves in test mode:
1 - without a target, 2, 3, 4 - when approaching a massive target:
FoxyPI v3.8
10/12/2020 at 07:14 • 0 commentsMinor update ( version 3.8 ) is ready (FoxyPIv3_8.ino.eightanaloginputs.hex):
improved display of signal curves in test mode (through earlier reading of preset settings, including contrast).
Echo of war
09/15/2020 at 06:31 • 0 commentsOne of the new finds in the garden with a metal detector FoxyPI (after electrolytic cleaning):
The thickness of the metal (5.5 mm) and the characteristic shape are an echo of WWII. I calculated the inner diameter, which turned out to be approximately 4.3 cm. -
GUARD parameter
08/03/2020 at 14:42 • 0 commentsInfluence of the value of the GUARD parameter on the detection range of the golden ring (L):
GUARD L, cm
500 ---> 12
750 ---> 10
1000 ---> 8
1500 ---> 7
It is possible to decrease it even below 500, but in this case false positives may appear.
Find
07/15/2020 at 05:09 • 0 commentsAn interesting find in the garden with FoxyPI - an unusual chrome detail (photo after electrolytic cleaning):
Errors
07/08/2020 at 05:44 • 0 commentsErrors that may occur during zeroing:
ERR 01 - the saturation section was not found in the signal:
* coil break
* no pulse generation
* the signal during zeroing is so strong that the saturation region is shifted beyond the registration windowERR 02:
* the signal during zeroing is strong enough so that the saturation region lasts until the end of the registration window -
FoxyPI firmware v3.7
07/05/2020 at 19:26 • 0 commentsFoxyPI firmware v3.7:
FoxyPIv3_7.ino.eightanaloginputs.hex
What's new in version 3.7:
* small code optimization was performed to increase the stability of the metal detector
+ beep indication for errors ERR 01 and ERR 02 added -
Service menu
06/30/2020 at 12:39 • 0 commentsService menu in firmware v3.6:
Firmware v3.6 is ready!
06/29/2020 at 08:33 • 0 commentsFoxyPI firmware v3.6:
FoxyPIv3_6.ino.eightanaloginputs.hex
What's new in version 3.6:
+ added the ability to configure the guard interval using the GUARD item of the service menu;
+ added auto-tuning of levels 1 and 2 of the audiovisual indication in static mode;
+ integrated test mode (to activate, after switching on, hold the control button until the graph of the signal curve appears)
