Firmware v3.6
06/29/2020 at 07:12 • 0 commentsFoxyPI with firmware 3.6 - golden ring test:
Finds with FoxyPI
06/24/2020 at 13:06 • 0 commentsFinds in our garden with FoxyPI (after electrolytic cleaning):
Voltmeter
06/18/2020 at 15:03 • 0 commentsThe double-pole switch with locking in the neutral position and the digital LED voltmeter allow you to determine the voltage of the uC/power battery in any mode of MD operation:
Stability of operation
02/07/2020 at 09:14 • 0 commentsI decided to numerically evaluate the stability of my metal detector - it turned out to be quite satisfactory: after 15 minutes of operation, the detection range of targets decreases by less than 4%.
Service menu
01/21/2020 at 06:35 • 0 comments
Service menu structure in version 3.5: -
Firmware v3.5
11/11/2019 at 12:35 • 0 commentsThe FoxyPI firmware version 3.5 is ready - FoxyPIv3_5.ino.eightanaloginputs.hex
What's new:
added the ability to adjust the display contrast using the CONTRAST item in the service menu
An example is small/normal/excessive contrast:
Video illustration of metal detector starting procedures
11/02/2019 at 06:31 • 0 comments -
Interferences
09/29/2019 at 21:03 • 0 commentsInterference from a nearby induction energy meter:
FoxyPI v3.4
09/25/2019 at 15:17 • 0 commentsThe final firmware version 3.4 is ready - FoxyPIv3_4.ino.eightanaloginputs.hex
What's new:
- MOSFET overheating is excluded
- increased stability
- added auto-tuning interval between ADC samples
- added display of the signal curve after auto-balancing
And here is how the interference from a nearby LCD TV appears:
