DPS control allows accurate tracking from very low speed to very high speed. It is a Servo control algorithm that can be applied to VESC firmware as a custom application.
- DPS Control means Degree Per Second Control
- I can command target velocity as DPS unit
- The motor is controlled to track precise position profile to follow the target velocity
