I added to the "nanocomputer" the possibility of input-output via an audio file or magnetic tape.
Board for matching voltage levels (classic solution):
Formats:
Bits in Audacity:
Functionality was checked for the linear input and output of a "large" computer with a speed deviation of up to 20%.
Example (WAV-file with three blocks):
CAUTION! HIGH VOLUME!
