Digging into SD card writes means shifting gears from the Boot BIOS source code since the Boot BIOS code only does reads. The CP/M BIOS code (CBIOS128.LST) which does the reads/writes after booting. Here's the BIOS code for writes to the SD Card:
0754 EAC4 ;================================================================================================ 0755 EAC4 ; Write physical sector to host 0756 EAC4 ;================================================================================================ 0757 EAC4 0758 EAC4 writehst: 0759 EAC4 F5 PUSH AF 0760 EAC5 C5 PUSH BC 0761 EAC6 E5 PUSH HL 0762 EAC7 0763 EAC7 DB 89 wrWait1: IN A,(SD_STATUS) 0764 EAC9 FE 80 CP 128 0765 EACB 20 FA JR NZ,wrWait1 0766 EACD 0767 EACD CD 2B EA CALL setLBAaddr 0768 EAD0 0769 EAD0 3E 01 LD A,$01 ; 01 = Write block 0770 EAD2 D3 89 OUT (SD_CONTROL),A 0771 EAD4 0772 EAD4 0E 04 LD c,4 0773 EAD6 21 D2 FB LD HL,hstbuf 0774 EAD9 wr4secs: 0775 EAD9 06 80 LD b,128 0776 EADB wrByte: 0777 EADB 0778 EADB DB 89 wrWait2: IN A,(SD_STATUS) 0779 EADD FE A0 CP 160 ; Write buffer empty 0780 EADF 20 FA JR NZ,wrWait2 0781 EAE1 0782 EAE1 7E LD A,(HL) 0783 EAE2 D3 88 OUT (SD_DATA),A 0784 EAE4 23 INC HL 0785 EAE5 05 dec b 0786 EAE6 20 F3 JR NZ, wrByte 0787 EAE8 0788 EAE8 0D dec c 0789 EAE9 20 EE JR NZ,wr4secs
The command to write to the SD card is 0x01. This is distinguished from reads which have a command of 0x00. The function SDWriteCommand( ) needs to call the read SD function or write SD function depending on the value.
The status value will require some thought. Here's the three values used by the sector read and sector write functions under the Z80 FPGA version of CP/M:
- 0x80 (128 dec) - SD interface is busy
- 0xE0 (224 dec) - Byte read in progress
- 0xA0 (160 dec) - Byte write empty
CP/M sectors are 128-bytes. Grant's code performed a tradeoff and set the sector size to 512-bytes. That's taken care of with the wr4secs loop.
I messed around with the status values and got writes partly working (at least not hanging). I got this:
>RUN >SAVE "MY.BAS" Close error >BYE
And the directory looks messed up:
A>dir A: DOWNLOAD COM : LOAD COM : PIP COM : STAT COM A: SUBMIT COM : DDT COM : DISPLAY COM : DUMP COM A: ED COM : ASM COM : BBCBASIC COM : POWER COM A: MBASIC COM : BAS BAS : BLINKLED BAS : blinkled bas A: 0@@@ : .@@@ : 2@@@ : 2@@@
I think I'll go back to the PSoC debugger side. First I need to create a new SD so that I don't mess up this one.
I did copy the 128MB disk using HxD and should be able to re-create it again if I had to.
