There were some things I wanted to add/change on the first rev of the card. Got the PCBs back from PCBs fabrication but haven't assembled the cards yet. This change:
- Adds Z80 expansion connector (J5)
- Fixes labeling on the Programming connector (H2)
- Adds control signal labels for SRAM debugging (WR*, RD*, and CS*)
- Adds a pin 1 indicator for the PSoC "Small dot >" (at U4)
- Adds I/O Connector (H4)
- Rotate I2C connector to allow horizontal header to be used
- Might want to use right angle connectors at J4, H2, H3, and H4
Z80 Bus Expansion Connector
The primary feature added is the 40-pin bus expansion connector which brings out the Z80 bus. Here's the connector pinout:
H4 I/O Connector
Also added a 6-pin connector for additional I/O (maybe an RS-232 port?). Pxx are PSoC pins.
