I ordered a batch of 10 boards from JLCPCB.
![](https://cdn.hackaday.io/images/5803301569497622752.png)
Final design has the following features:
- Z80 CPU - any speed from 4 MHz to 20 MHz should work
- 512KB Static RAM, 55 nS, Zero Wait State data and program memory
- PSoC5LP - Cypress Semiconductor System on a Chip
- $8 part
- 32-bit ARM CPU
- 5V logic levels - all glue logic in PSoC
- USB interface
- I2C interface with interrupt input line
- RTC with 3V 2032 battery
- Serial connections with handshakes (could use external FTDI or RS-232 transceiver)
- 8-bit DAC output
- Emulates Z80 peripheral chips in PSoC firmware
- Flexible Memory Mapper
- Maps the 512KB SRAM into the Z80's 64KB space
- Software-selectable bank sizes from 2K to 32KB
- Can be configured "on-the-fly" or by compiling PSoC code for particular software
- Z80 sets the banks with a write in I/O space - compatible with various software memory management schemes
- LED - controlled by PSoC
- Optional I2C Port Expander
- MCP23017
- Adds 16 bits of programmable I/O
- Optional oscillator
- Not required for most applications since PSoC controls all interfaces and has an accurate trimmed internal oscillator
- Connectors
- I2C
- USB B
- Serial TTL-level
- 95x95mm form factor with mounting holes
