It is really, really easy to debug the I/O emulator using the PSoC debugger. I can single step through the code. With the DSLogic+ Logic analyzer I can even see the I/O instructions being sent from the Z80 one at a time. Here's one of the CPU cycles.
This corresponds to the code:
0408 01AE 3E 04 LD A,$04 0409 01B0 D3 02 OUT (SIOA_C),A
I've split up the code into Z80_IO_Handle.c and Z80_SIO_emul.c code. The Z80_IO_Handle file looks at the address of the IO and calls the appropriate code in Z80_SIO_emul file. This lets the emul code handle the pair of writes to the control register(s).
Got the I/O writes to SIO working. Here's the timing of writing the SIO_A registers:
Here is one IORQ* cycle zoomed in:
This is 2uS wide IORQ*.
land-boards.com
