Replaced the 6 MHz Z80 with a 10 MHz Z80 part. This change is very simple in PSOC Creator. Just set the CPUCLK to 10 Mhz.
![](https://cdn.hackaday.io/images/1740631572690777160.jpg)
It works.
Tried overclocking at 12 MHz and it worked. Booted CP/M. Ran MBASIC.
Also tried 15 MHz and it also worked.
A project log for 3-Chip Z80 Design
Combining a Z80 retro design with a modern PSoC CPU.
It works.
