In the last log we got the Multi-boot monitor to run however, when BASIC was run it hung.
The Z80 is trying to access I/O address 0x39 which isn't implemented yet. That's the swap back to the original BIOS code. Since it was never swapped out it can be swapped right back in with an ackIO( ).
After adding back in the BIOS, BASIC now works as launched from Multi-boot with the S5 command.
Cold or Warm? Memory top? Z80 BASIC Ver 4.7b Copyright (C) 1978 by Microsoft 57694 Bytes free Ok 10 print "HI" run HI Ok list 10 PRINT "HI" Ok
Added in code that when the 0x39 (swapped back) is received then goes and causes a BUSREQ*, waits for a BUSACK* and copies the BIOS back into SRAM.
Back to Debugging CP/M
The CP/M code is in and the BIOS code looks like this:
; Disable the ROM, pop the boot disk and IOBYTE from the stack
; (supplied by monitor), then start the OS
; org 0FFB0h
popAndRun:
ld A,01h
out (38h),A ; kick ROM
pop AF ; Monitor gives physical boot volume
ld (mnttab),A ; ignore 8 bit volume number
pop AF ; Monitor gives the IOBYTE ...
ld (IOBYTE),A
ld HL,mnttab
ld (0FFFEh),HL ; put mounttab vector in FFFE
ld HL,backdoor
ld (0FFFCh),HL ; put backdoor vector above that
ld A,0C3h
ld (0FFFBh),A ; and a JP opcode above that
ld C,0
jp BIOS
S2 also works.
Z80 CP/M BIOS 2.20 Based on MULTICOMP by G. Searle 2007-13 http://searle.hostei.com/grant/Multicomp CP/M 2.2 (c) 1979 by Digital Research STARTUP? A>dir A: Volume 002 : ASM COM : DDT COM : DISPLAY COM A: DOWNLOAD COM : DUMP COM : DUTIL COM : ED COM A: LOAD COM : MOUNT COM : PIP COM : RDINIT COM A: RESET COM : STAT COM : SUBMIT COM : TIME COM A>
S3 also works.
CP/M V3.0 Loader Copyright (C) 1998, Caldera Inc. BNKBIOS3 SPR FA00 0600 BNKBIOS3 SPR 7400 0C00 RESBDOS3 SPR F400 0600 BNKBDOS3 SPR 4600 2E00 61K TPA CP/M Version 3.0 BIOS (2016/9/13) FPGA-Z80 Multicomputer Original concept by Grant Searle A>
S4 boots but hangs.
MP/M II V2.1 Loader Copyright (C) 1981, Digital Research Nmb of consoles = 4 Breakpoint RST # = 6 Memory Segment Table: SYSTEM DAT FF00H 0100H TMPD DAT FE00H 0100H USERSYS STK FC00H 0200H XIOSJMP TBL FB00H 0100H RESBDOS SPR EF00H 0C00H XDOS SPR CD00H 2200H BNKXIOS SPR C200H 0B00H BNKBDOS SPR 9F00H 2300H BNKXDOS SPR 9D00H 0200H TMP SPR 9900H 0400H LCKLSTS DAT 9600H 0300H CONSOLE DAT 9200H 0400H ------------------------- MP/M II Sys 9200H 6E00H Bank 0 Memseg Usr 0000H C000H Bank 1 Memseg Usr 0000H C000H Bank 2 Memseg Usr 0000H C000H Bank 3 Memseg Usr 0000H C000H Bank 4 Memseg Usr 0000H C000H Bank 5 Memseg Usr 0000H C000H Bank 6 Memseg Usr 0000H 9200H Bank 0
S6 doesn't boot.
S7 boots.
> S7
CP/M V3.0 LoaderBIOS for Grant Searle's Multicomputer
Loading ZPM3...
61K TPA
ZCPR compatible system for CP/M+ by Simeon Cran
Loading NAMES.NDR
RamDisk: Initialized
00:00 A0:SYS>
Tried S1 twice and it booted on the second try.
Z80 CP/M BIOS 2.20 Based on MULTICOMP by G. Searle 2007-13 http://searle.hostei.com/grant/Multicomp Dos+ 2.5 Copyright 1986 (c) by C.B. Falconer CCP+ Ver. 2.2 A>
zexall runs on S1.
A>A:DOWNLOAD zexall.com ................................................................ .... OK A>zexall Z80 instruction exerciser <adc,sbc> hl,<bc,de,hl,sp>.... OK add hl,<bc,de,hl,sp>.......... OK add ix,<bc,de,ix,sp>.......... OK add iy,<bc,de,iy,sp>.......... OK aluop a,nn.................... OK aluop a,<b,c,d,e,h,l,(hl),a>.. OK aluop a,<ixh,ixl,iyh,iyl>..... OK aluop a,(<ix,iy>+1)........... OK bit n,(<ix,iy>+1)............. OK bit n,<b,c,d,e,h,l,(hl),a>.... OK cpd<r>........................ OK cpi<r>........................ OK <daa,cpl,scf,ccf>............. OK <inc,dec> a................... OK <inc,dec> b................... OK <inc,dec> bc.................. OK <inc,dec> c................... OK <inc,dec> d................... OK <inc,dec> de.................. OK <inc,dec> e................... OK <inc,dec> h................... OK <inc,dec> hl.................. OK <inc,dec> ix.................. OK <inc,dec> iy.................. OK <inc,dec> l................... OK <inc,dec> (hl)................ OK <inc,dec> sp.................. OK <inc,dec> (<ix,iy>+1)......... OK <inc,dec> ixh................. OK <inc,dec> ixl................. OK <inc,dec> iyh................. OK <inc,dec> iyl................. OK ld <bc,de>,(nnnn)............. OK ld hl,(nnnn).................. OK ld sp,(nnnn).................. OK ld <ix,iy>,(nnnn)............. OK ld (nnnn),<bc,de>............. OK ld (nnnn),hl.................. OK ld (nnnn),sp.................. OK ld (nnnn),<ix,iy>............. OK ld <bc,de,hl,sp>,nnnn......... OK ld <ix,iy>,nnnn............... OK ld a,<(bc),(de)>.............. OK ld <b,c,d,e,h,l,(hl),a>,nn.... OK ld (<ix,iy>+1),nn............. OK ld <b,c,d,e>,(<ix,iy>+1)...... OK ld <h,l>,(<ix,iy>+1).......... OK ld a,(<ix,iy>+1).............. OK ld <ixh,ixl,iyh,iyl>,nn....... OK ld <bcdehla>,<bcdehla>........ OK ld <bcdexya>,<bcdexya>........ OK ld a,(nnnn) / ld (nnnn),a..... OK ldd<r> (1).................... OK ldd<r> (2).................... OK ldi<r> (1).................... OK ldi<r> (2).................... OK neg........................... OK <rrd,rld>..................... OK <rlca,rrca,rla,rra>........... OK shf/rot (<ix,iy>+1)........... OK shf/rot <b,c,d,e,h,l,(hl),a>.. OK <set,res> n,<bcdehl(hl)a>..... OK <set,res> n,(<ix,iy>+1)....... OK ld (<ix,iy>+1),<b,c,d,e>...... OK ld (<ix,iy>+1),<h,l>.......... OK ld (<ix,iy>+1),a.............. OK ld (<bc,de>),a................ OK Tests complete CCP+ Ver. 2.2 A>
land-boards.com
