It's been a while. I plugged in the board USB and forgot how to run it. I even forgot which button I needed to press on the front panel to get Multiboot to run. This Hackaday page helped me remember. Glad I made it.
Decided to add hints to the PSoC monitor menu. Got a bit carried away but it's really easy now.
The PSoC now boots to the following screen showing what the Front Panel buttons do:
Z80_PSoC - Running Front Panel SW25 SW26 SW27 SW28 SW29 SW30 SW31 SW32 Run Mon N/A N/A N/A LDAD STOR INCA SW17 SW18 SW19 SW20 SW21 SW22 SW23 SW24 A15 A14 A13 A12 A11 A10 A9 A8 SW9 SW10 SW11 SW12 SW13 SW14 SW15 SW16 A7 A6 A5 A4 A3 A2 A1 A0 SW1 SW2 SW3 SW4 SW5 SW6 SW7 SW7 D7 D6 D5 D4 D3 D2 D1 D0 Press SW25 (upper left button) to exit Front Panel and run Z80 Press SW26 to run Monitor/Test Code
Pressing the upper left button on the Front Panel (SW25) goes directly to Multiboot.
The next button in boots the monitor. The monitor looks like:
Land Boards, LLC - Z80_PSoC monitor I - Initialize SD Card B - Blink LED F - Read Front Panel Rxxxxxxxx - Read sector xxxxxxxx from the SD Card N - Read next sector from the SD Card W - Write to the SD Card at 2GB - 1 sector X - eXit Monitor and run Z80 ? - Print this menu
Pressing X goes to Multiboot.
The PSoC waits until the USB terminal (PuTTY) is running. Now I feel like I could plug the card in anytime and just use it. Added P-Touch labels to SW25, SW26 to remind me what they do.
Also noted that the USB Serial port can be set to any baud rate since the PSoC automatically adjusts. Tried 230.4 kb and it worked just fine.
