I just really could not be happier at this point and have been posting this everywhere else on the Intercats, so this page should get the update too :)
The new metal bits I described in the previous post are installed. Set screws are biting hard against metal vs. sqooshing into nylon. It's like a whole new rover!
Steve
No, that's actually happening IRL and is yet-to-be-debugged issue.
It might be because one servo is just in plain better shape that the other(s)(These Dynamixels saw some use before being installed on Tenacity). It could also be that the servo firmware is not programmed the same on all 4.
I should look into that.
I'm glad you liked the video. Thanks for inspiring all of us SAWPPY-builders with your project in the first place.
I checked out the individual servos w/ Dynamixel manager yesterday and they're all programmed the same. I think the next thing to do is go look at the dynamixel driver ROS node.
I'm thankful for your research and report into 3D printed shafts so we all know the current state of the art, and happy to see Tenacity up and running on metal shafts.
Question: the (from Tenacity's perspective) right front steering servo appears to move to new position much more quickly than the left front steering servo. Is that just an artifact in the video or does that reflect reality?
