I've charged 4x2000mAh cheap cells externally and just put them into the B&D vacuum for runtime testing.
I've used the vacuum for around 20-25 times for cleaning the cat litter and hair around the apartment.
-> 1 week without charging
I think this is enough, because I don't want to have the charger always on.
Next steps:
- Waiting for the BMS module for balanced charging
- Writing the HD instructions :-)
