Yesterday I've disassembled the vacuum cleaner and tried to connect the new battery pack.
My first try was a combination of 2 18650 cells in a cheap battery holder with a 10A battery protection board ( https://www.aliexpress.com/item/32920842556.html ).
It was not possible to start the motor, the short circuit protection immediately kicks in and cuts of the power.
Next try:
20A board. There are 30A boards as well, but only for 3S, which would be too much for the motor (original voltage: 9.6V; 2S: 7.2V; 3S: 10.8V).
https://www.aliexpress.com/item/32863604994.html
with a balancing circuit (~2$).
benjaminaigner
