diPlayer
Raspberry Pi-based hardware player for DI.FM
Based on the idea of the Plastic Player by Brendan Dawes, I created my version of the hardware player.
It's main purpose is playing DI.FM IceCast streams. You control the player by inserting the slides that have NFC-stickers on them that correspond to the predefined channels.
Built using Raspberry Pi and Arduino. The Arduino controls the small OLED screen, NFC module and the play/pause button. It communicates with Raspberry Pi over USB with serial.Raspberry Pi runs Pi Musicbox and a custom Python program that communicates with Arduino, rotary encoder and the mpc player.
The projects took me around 2-3 months of active evening almost daily and some weekends.Had to do a couple of things
  • 1 × Raspberry Pi 3B+
  • 1 × Arduino Nano
  • 1 × Elechouse PN532
  • 1 × OLED 128x32
  • 2 × Anti-vandal buttons
View all 7 components
Alexander Dvorkovyy wrote 11/25/2021 at 23:10 point
I like the idea of using physical card to choose which music to play. Must be joy to use. Do not understand why, but I believe it is :)
So, it is essentially a RaspberryPi HAT? Very clever. In this way you do not have to worry about streaming itself and music part, I presume. There is Pi Musicbox which does the job. HAT is only for sensing the card and sending a signal to the Pi Musicbox. Right?
This concept can be used actually for any music service supported on RaspberryPi, not only DI.FM
Gerben wrote 09/24/2019 at 13:47 point
I thought DI stopped icecast streams. Or are you a premium member?
Alex Buznik wrote 09/24/2019 at 14:01 point
Yes, I'm a premium member.
