Based on the idea of the Plastic Player by Brendan Dawes, I created my version of the hardware player.It's main purpose is playing DI.FM Icecast streams. You control the player by inserting the slides that have NFC-stickers on them that correspond to the predefined channels.Built using Raspberry Pi and Arduino. The Arduino controls the small OLED screen, NFC module and the play/pause button. It communicates with Raspberry Pi over USB with serial.Raspberry Pi runs Pi Musicbox and a custom Python program that communicates with Arduino, rotary encoder and the mpc player.The projects took me around 2-3 months of active evening almost daily and some weekends.Had to do a couple of things
I like the idea of using physical card to choose which music to play. Must be joy to use. Do not understand why, but I believe it is :)
So, it is essentially a RaspberryPi HAT? Very clever. In this way you do not have to worry about streaming itself and music part, I presume. There is Pi Musicbox which does the job. HAT is only for sensing the card and sending a signal to the Pi Musicbox. Right?
This concept can be used actually for any music service supported on RaspberryPi, not only DI.FM
