I'm finally ready to put this project is a chassis of some sort. I found an unused DSL modem that might hold the project. If it does at all, it will be a tight fit.
All the above needs to fit in the case below:
Any questions?
A project log for IR Activated IrDVR
Raspberry Pi based, portable security ir camera with IR motion detector
Any questions?
