With recent long run tests, the Pi has been going offline. Ping tests over wifi are averaging 5% packet loss. It could be environmental, or possibly hardware. I will test environment first, moving the device to another room. If the dongle supports 5GHz, I will give that a try as well. The USB dongle was dirt cheap, so i could get a gross of them, if they last a year or so as my current one has.
visualkev
