I think the low battery detector misfires when the camera and the flashlight turn on causing the power supply to dip, but it doesn't happen every time. My multi-meter isn't fast enough to register such a short blip. I need to figure out a fix based on that hypothesis, probably a capacitor across the power supply to flatten out the dip a bit
visualkev
