![](https://cdn.hackaday.io/images/7733521570156566692.png)
- The PROG (Programming header) could be right angle.
- Fuse on USB power protects the Host computer USB power and protects from rogue hats.
- 3.3V power regulator for PSoC and hat.
- 12 PSoC I/O pins @ 3.3V (P3).
- 16 PSoC I/O pins @ 3.3V or 5V (group selected by jumper H3)
- USB connector is relatively expensive ($2) but has mechanical mounting so it should be tolerant of a lot of connect/disconnects
