Planning the layout
A project log for Super Micro Relay Computer
Going back almost 200 years, to what could have been the very early beginning of electronic computing!
stefanoStefano • 10/28/2019 at 20:08•0 Comments
The frame start to get populated:
50 might be a little number of relays but surely is already providing quite an intricate mess of wires and a lot of headaches if not properly planned (and even if properly planned): at least let's try to manage at best!
Following a bit more detailed overall schema of the PC (more details of the various circuits will come in later posts):
And below a tentative to put some order between units in the frame:
As of last image a drawing guide for the wiring of the first bit of the ALU (the famous "no dollars" one of @roelh):
(the full layout of the MY4NJ can be found in first project log)
