Final version, probably.
A project log for Clio2JVC
Arduino based signal converter, enabling stalk remote in Renault Clio to control JVC radio.
karolKarol • 08/12/2021 at 15:28•0 Comments
I spent some time working on the issues mentioned in the previous log. Unfortunately, I wasn't able to fix the initialization failures. Loop caused it to be even worse, so I reverted it. On the other hand, I fixed some other bugs and now I think it will be the final version.
There is one new functionality - the menu, where users can turn on and off the auto-volume as well as adjust its parameters. Also, there is a possibility to select the default display mode. Thanks to EEPROM it is no longer required to plug it into a PC to change these settings.
Currently, I plan to use this car for the next few months, then I'll try to get something newer. Obviously, this would mean that the project development will be over.
Still, that was fun to develop and use it. If anyone ever wanted to replicate this project, feel free to contact me.
