This project is at the concept stage. If you are interested in contributing or provide feedback, please use the comments system. If successful I may launch a Kickstarter and will make the source and gerbers available on GitHub.
To do:
- Design the sensor hardware platform - from the CC2358 reference design + battery power supply.
- First implementation will be for a pool chemical sensor that I am in the process of designing.
- Implement the Thread drivers on Windows (being developed by Microsoft now)
- Integrate IoT.js JavaScript engine into the ARM M3 code from the CC2358 Thread reference implementation, including a UDP terminal function and MQTT for pub/sub.
- Prototype the board and software
- Implement the next version of Iotivity for plug and play IoT.
- Release on GitHub
