Battery Capacity Measurement, Identify a Fake Battery, Using Arduino [Lithium-NiMH-NiCd]
Features:
Identify a fake Lithium-Ion/Lithium-Polymer/NiCd/NiMH battery
Adjustable constant current load (can also be modified by the user)
Capable of measuring the capacity of almost any kind of battery (below 5V)
Easy to solder, build, and use, even for beginners (all components are Dip)
An LCD user interface
Specifications:
Board Supply: 7V to 9V(Max)
Battery Input: 0-5V(max) – no reverse polarity
Constant Current Load: 37mA to 540mA(max) – 16 Steps – can be modified by the user
The true measurement of a battery’s capacity is essential for many scenarios. A capacity measurement device can solve the problem of spotting fake batteries as well. Nowadays fake Lithium and NiMH batteries are everywhere which don’t handle their advertised capacities. Sometimes it is difficult to distinguish between a real and a fake battery. This problem exists in the spare batteries market, such as cell phone batteries. Furthermore, in many scenarios, it is essential to determine the capacity of a second-hand battery (for instance a laptop battery). In this article, we will learn to build a battery capacity measurement circuit using the famous Arduino-Nano board. I’ve designed the PCB board for dip components. So even beginners can solder and use the device.
hesam.moshiri
