This will need to be printed at a high resolution with a resin printer of some type:
Editable design is available here!
This is an editable 3D design for a mouse brain matrix for neuroscience histology
MouseBrainMatrix112419.stlSlight updatesStandard Tesselated Geometry - 638.75 kB - 11/24/2019 at 18:03 |
MouseBrainMatrix.stlSTL file for the matrixStandard Tesselated Geometry - 3.81 MB - 10/10/2019 at 17:13 |
The editable TinkerCAD file for this project is available here.
These prints were outsourced to a commercial supplier - they cost ~$2 each and came out nice!
Can you confirm that the slice spacing is 1 mm increments?
Hi Phil - they are spaced at 1.2mm increments. Each "fin" is 0.6mm thick and each space between is 0.6mm. I forget why I did this instead of 1.0mm, it might have just been easier to print with the spacing a little thicker. The editable design file is here: https://www.tinkercad.com/things/ePmgy8KqMFm, would be trivial to edit to 1.0mm spacing. If you aren't familiar with TinkerCAD I can do it for you too let me know.
I'll also throw out that the specific dimensions of the physical part will depend on the printer you use and its tolerance
Hi! Yup I printed these at WeNext.hk - the white one is Somos GP resin, and the clear one is Somos clear resin.
Hey there, Is Derek from WENEXT. Our website is www.wenext.com
For any needs, please do not hesitate to contact us.
Cheers
Hi There,
Would you be okay sharing what commercial supplier you used to get these printed?
Thanks!
Alfredo
Hey, Lex. Awesome design (as usual). It is finding use here at UCDenver! I see two files. Is the slightly updated one just with some material removed for ease of printing? Thanks!
