Printnum is the routine that converts a 16-bit binary number to a 5-digit ascii string.
I covered it a few days ago - but was not happy with the large blocks of code that were repeated 4 times over.
Now that I have the CALL and RET subroutine mechanism working, I decided to rewrite the routine using one subroutine labelled "Decimate" that is called 4 times, each time with a different decimation factor (10,000, 1000, 100 and 10) stored in R1.
The result is much simpler and shorter code - and easier to understand. It is 39 words long, whereas its predecessor was 84 words.
Here is the new version printnum_2
// 0x0010 ---------------------------PRINTNUM_2-----------------------------------------
// R1 = Decimation Value
// R2 = digit
// R3 = 0x30
// R4 = temporary storage for accumulator (decimated value)
0x1200, // SET R2, 0x0000
0x0000,
0x1300, // SET R3, 0x0030
0x000,
0x1100, // R1 = 10,000
0x2710,
0x082C, // CALL decimate
0x1100, // R1 = 1000
0x03E8,
0x1100, // R1 = 100
0x0064,
0x1100, // R1 = 10
0x000A,
// 0x0020 ---------------------------------------------------------
0xA300, // ADD R0, R3 to make a number
0x0C00, // putchar R0
0xB300, // SUB R3 to restore accumulator
0x1000, // SET R0, CR
0x000D,
0x0C00, // putchar R0 CR
0x1000, // Set R0, LF
0x000A,
0x0C00, // putchar R0 LF
0x0000, // BRA START
0x0F00, // NOP
0x0F00, // NOP
// 0x002C ------------------------Decimate--------------------------------
0xB100, // SUB R1, :Decimate
0x0230, // BLT 0x30
0xE200, // INC R2
0x002C, // BRA 0x02C
// 0x0030 ---------------------------------------------------------
0x3400, // Store R0 in R4
0x2200, // MOV R2, R0,
0x2400, // Get R0 back from R4
0xA100, // ADD R1 adds DEC value to restore R0
0x1200, // SET R2,0 Reset R2
0x0000,
0x0900, // RET
