Drop Seeder, Put those seeds in the soil quick
Seeding takes time and is relatively boring, this drop seeder will mean I have more time to do fun things.
Well Im back to making things and have a day a week to work on open source projects just for the fun of it [mainly farming tools]:
As usual the designs are open source, link is below.
You will need a Laser cutter. BOM in the thingiverse files.
Want to Make one:
https://www.thingiverse.com/thing:3911941
Want to Buy one:
Contact mike@aquaponicslab.org
Depending on the size of tray you want to use the price varies from $120-$300
The one showed is £180 as an example
How it works:
This tools works best if your using a dibbler like below:
https://hackaday.io/project/167679-dibbling-plate-put-those-holes-in-the-soil-quick
Video client made:
View all 2 project logs
andreshinkey wrote 05/04/2020 at 23:03 • point
Does that mechanism to slide the bottom plate jamb up ever since its actuated only from the one side? Perhaps when it gets dirty.
Dan Maloney wrote 10/17/2019 at 16:09 • point
Pretty slick! Along with that dibbler you made, this would make seeding flats on a commercial scale pretty painless.
