Finally, assembled couple of PCBs:
Now can debug drivers and print case.
I'm still thinking about USB-PD version. It should contain less components and be more compact. Anyway, software architecture is flexible enough to support both. We will continue with current PCB to test usability, and will order USB-PD version in parallel.
Vitaly
